Headlight question
Old May 24, 2006 | 01:36 PM
vipercwf's Avatar
Default Headlight question
On the '06 1000rr, I am just curious. For the front headlight, if I need to replace the bulb, can just the bulb be removed or does the unit as a whole have to be removed. The bulb is attached to a two prong connector. Is this a whole unit, or can just the bulb itself be removed?
Old May 24, 2006 | 03:01 PM
m007slater's Avatar
Default RE: Headlight question
the bulb can easily be changed by simply peeling the rubber grommet off around back of bulb connections , then pull off connector and behind grommet is a clip which holds bulb in place , unclip an d thats it . then reverse this method using new brighter bulb . ( existing are a bit boring )
Old May 27, 2006 | 04:36 AM
vipercwf's Avatar
I want to get the "white" light bulbs, like the hyper white. What should I get for my bike to use in it. (I just want to replace the bulb, and not get those HID kits or whatever, cause they are really expensive right?)
Old May 29, 2006 | 09:27 PM
recker's Avatar
Yes you can just get the " white " bulbs, i have a set in my bike now and they look good...It takes no longer than a couple minutes to install them.. im thinking of getting the hid kit for my bike so i will let u know how i go if i get it.
inkredibleg
Apr 9, 2008 09:45 PM
malibuken65
Apr 14, 2007 11:42 PM
fiveoh
Apr 1, 2007 09:06 PM
Tantric
Mar 20, 2007 01:41 PM
spidertron
Apr 29, 2006 02:43 PM
