Gas Tank Lines
Old Aug 23, 2008 | 11:30 PM
mercenaryferret's Avatar
Default Gas Tank Lines
Ok, so I finally got around to putting on my Juicebox (which is awesome btw) and after reinstalling all the wires, tubes, etc I found to have an extra tube coming out of the gas tank that looks like it should plug into something.
I have the main tube that the fuel goes through as well as the one that runs to the bottom and out where the other 3 come out the bottom fairing. What is left is a very short tube (about 4 inches in length) and I cannot figure out where it goes, but it looks like it should be somewhere. Not sure if this is a 'vent' or something else, but if anyone could help out I would appreciate it.
Thanks
PS. I will try and throw a pic up if someone needs it, just dont feel like taking the gas tank off again :P
Old Aug 23, 2008 | 11:52 PM
TBagr's Avatar
Default RE: Gas Tank Lines
i installed my juice box and am familiar with the area but need a pic as i cant visualize what you are saying. gimme a pic and i can helpya out.
Old Aug 24, 2008 | 12:04 AM
i will try and get a pic up tomorrow, but if it helps the line is the only short one. Its literally only about 3-4 inches long and the others arent even close to being that short.
Old Aug 24, 2008 | 03:26 AM
TBagr's Avatar
does it have any type of connector on the end? are both ends loose? one end attached to anything? is there a open connector on the bottom of your tank? if you look in from the left leg side of the bike with a flashlight you can see the spot under the tank that has the connections.
imran89
Apr 13, 2014 08:17 PM
Jeffy_2010
Apr 9, 2014 10:03 AM
todem76
Jan 16, 2012 07:47 PM
LJ Harp
Oct 6, 2010 02:06 PM
George
Oct 20, 2009 09:44 PM
