Fork Seals....Oil Weight Questions
Old Feb 8, 2011 | 04:43 PM
dont under estimate 1 liter's Avatar
Default Fork Seals....Oil Weight Questions
I have and 07' cbr 1000rr. Doing the fork seals for first time.
Had a question...I pull ALOT of wheelies. Should I put in heavier fork oil?
Does anyone have any suggestions of oil and seals etc?
Old Feb 8, 2011 | 05:17 PM
airxsports's Avatar
Have you ever bottomed them out coming down? If so I would stick with the same weight or even heavier to slow down the flow.
If your not, maybe try a lighter oil which should make it a little more forgiving on the way down.
I've only been in the field for two years and haven't ran into this issue but thats my best advice.
Old Feb 9, 2011 | 09:38 AM
Yeah I have bottomed coming down. Not all the time but it does happen. I am not a heavy Person especially for the 1000 I only weight 165lbs and Im 5'6". Does anyone on here know if I should mess with compression and rebound clickers and if so What should I set them to.
Old Feb 9, 2011 | 01:05 PM
backdoc's Avatar
I would stick to the recommended fork oil weight. Preload is what will keep you from bottoming out. The more preload (clockwise turns in) in your forks the stiffer they get decreasing the chance of bottoming out. As you increase preload though you raise the front which slows the steering. If your forks are set up too soft (very little preload) then it will be easier to bottom out.
What settings are you using right now in your forks? The settings on sportrider.com are a good baseline to start with.
I checked racetech's website and the stock springs in your bike are actually a little stiffer than required for your weight so either you have too little preload or you need to set the front wheel down softer when doing wheelies.
Compression and rebound are used to improve handling in curves or on a race track. They will not keep the forks from bottoming out.
Old Feb 9, 2011 | 04:34 PM
My clickers are set at stock settings. So I am not sure what exactly they are set to as of right now.
Old Feb 9, 2011 | 04:59 PM
backdoc's Avatar
Did you buy your bike new? If not you never know what the previous owner did to the suspension. The preload is the nut (19mm) on the top of forks and needs a socket or wrench to change. (Note: If your preload nuts look new place a papertowel over them then the socket to keep from scratching the nuts while you make changes) To get the correct setting turn the adjuster clockwise until it lightly seats then turn it counterclockwise 7 turns.
The compression (2 turns out) and rebound ( 1 turn out) can be changed with a screwdriver.
Try these settings from the link below. If you still bottom out turn the preload in/clockwise 1-2 more turns. This should keep you from bottoming out.
http://www.sportrider.com/suspension...ngs/honda.html
Old Feb 11, 2011 | 07:24 AM
Yes, I bought the bike new. And I will give that a try as soon as the parts get in and I get it back together and on bike Ill report back. Thanks for the help back doc.
Old Apr 1, 2011 | 06:25 AM
UnderAssumedName's Avatar
I just helped a friend replace the seals on his K7 Gixxer 1000.
I recommend using whatever oil the manual asks for and don't skimp on the seals. He bought some aftermarket ones and the fork that was leaking still leaked after the first fix. I helped him do both forks yesterday and he got some OEM seals (well they were better made than the other ones he bought).
You will also need special tools to take the forks apart. He bought a kit which included everything he needed for upside down forks. They aren't that expensive. It'll be really really hard to take them apart without the tools. Here's an example of what the tools look like (assuming you didn't know you needed them..)
PS: If you do a lot of wheelies you might want to change the bushings too but it's probably wise do do some research on that (to see if it's needed).
Old Apr 2, 2011 | 08:33 PM
jb90cbr1000's Avatar
Default rebuilding forks
know of any how to vids about how much was the tool kit
Old Apr 2, 2011 | 11:09 PM
letsride's Avatar
google is your friend.Also try youtube.
