clutch and brake levers
Old Dec 31, 2009 | 06:22 PM
militaryat17's Avatar
Default clutch and brake levers
alright , im new to working on my bike myself and thought that the levers for the brake and clutch were pretty straightforward ... well, after installing them my clutch just pops as soon as i put it in gear and i adjusted with the screw type thing by the clutch lever and it did nothing to help both screwed completely in and then as far out as it would go , i didnt adjust anything around the area where the clutch is located bc i wanted to check to see where i was supposed to go from here , thanks for any help
Old Jan 1, 2010 | 03:04 PM
mihomie's Avatar
what year bike? my 06 had a barrell on the clutch side that the pin from the slave goes into. did you take a barrell out of the old clutch lever?
Old Jan 2, 2010 | 05:11 PM
mine is an 08 and i just removed the clutch cable from the old lever and inserted it into the new one and secured the new one down , that was all now the clutch just pops as soon as you put it in first
Prennie
Jun 13, 2014 04:18 AM
Fordhamjc
Jun 5, 2013 02:17 PM
djhh212
Apr 20, 2007 03:28 PM
whizzif
Oct 27, 2005 04:58 PM
