CBR1000RR Turbo Duel stage boost controller!
Hi all Turbo Riders!
I’m building a duel stage boost controlled CBR1000RR -05 Turbo. Running, 7PSI and 16PSI. This is going to be a street bike and occasional strip riding.
This is the spec as of now built on a cycle-logic turbo kit;
7 PSI stock engine 11.9 compression,
Larger injectors,
Heavier valve springs,
Power commander with expansion hub,
To do; BOV, Intercooler
Now for the questions,
What is the maximum intake temperature that is safe? I have been told about 85C or 185F before you start to get in to big detonation problems?
What should I do with the MAP sensor, is here another one I can use or will the OEM be fine? Is there any other thing I need to think about regarding the OEM ECU functions when running duel stage boost controller?
I was going to lower the compression to 9.1 to 9.4, is that a good target?
Have anyone fit an intercooler with the OEM radiator, layering them?
Thank you for keeping the answers professional!
Robert
Larger injectors,
Robert
I drive a electric car to work so I think I'm entitled? What do you drive to work? It better not be faster than 60mph!!
