CBR 1000RR REAR BRAKE MODS
Old Apr 12, 2006 | 07:12 PM
5thread's Avatar
Default CBR 1000RR REAR BRAKE MODS
HI THERE THIS THE FIRST TIME I HAVE USED CBR FORUM AND WHAT A GREAT SITE IT IS. I HAVE JUST TRADED MY 2001 SP1 IN FOR A NEW 1000RR BLADE AND LOVE IT TO BITS. BUT I LIKE TO PERSONALISE MY BIKES TO MY TASTES. HAVING A 25 YEAR ENGINEERING BACKGROUND I OFTEN AMAZE MY BUDDIES WITH WHAT I CAN DO. HOWEVER YOU OFTEN SEE SOMTHING THAT CATCHES YOUR EYE, THE THING THAT HAS GOT ME WAS I SAW A SMALL GREEN PLASTIC TUBE THAT REPLACES THE REAR BRAKE FLUID CONTAINER ALSO THEY SAID THAT IT CAN ATRACT MOISTURE I JUST WONDERED IF THERE IS ANY TRUTH IN THIS I HOPE SOMONE CAN HELP ME. I WILL SEND SOME PICS OF MY BLADE IN SOON.
Old Apr 12, 2006 | 07:34 PM
Anubis's Avatar
Default RE: CBR 1000RR REAR BRAKE MODS
I have the same pipe mate, No problems really. You should change the fluid regularly anyway though. Welcome In
Old Apr 12, 2006 | 07:42 PM
MgA_ODEN's Avatar
They have a tendency to sweat , not attract.
Found on for sale HRC brake reservoir kit
Old Apr 15, 2006 | 02:46 PM
5thread's Avatar
THANKS VERY MUCH MATE I WILL BE MAKING ONE THEM PRETTY SOON.
Old Apr 15, 2006 | 02:47 PM
5thread's Avatar
THANKS VERY MUCH
Old Apr 16, 2006 | 02:05 PM
quans1000blade's Avatar
if i was you i would go for the g-craft dude
Old Apr 17, 2006 | 03:37 PM
rogfog's Avatar
I have gone down this route but after having been out for a run early in the week I have found that the G Craft master cylinder is rubbing agaisnt the swing arm scratching it for about 20-30mm along its travel.
I tried grinding a flat off the bottom of the cylinder but it is still catching on the arm - guess I'll have to file off a bit more. If it continues I think the HRC kit may be my next buy.
Old Apr 17, 2006 | 05:01 PM
jcf1977's Avatar
Get the HRC tube kit, I have it and it rocks...............
Old Apr 17, 2006 | 07:27 PM
05Tribal's Avatar
Does the HRC kit help performance wise? If so what does it do? I ask because the rear brake on my 06 1000RR feels real spongy compared to the 05 600RR. I am a big believer in using the rear brake and want it to perform as best as possible especially when I get good enough to use the rear brake to help me start the slide in my turns.
What web site are you using to get HRC parts? The only one I know of is not offering 1000RR parts for any model year.
Old Apr 18, 2006 | 01:00 AM
jcf1977's Avatar
works sweet for me, the rear brake is not designed to grab as hard as the fronts.....that's why you have that spongy feeling. Check your 600rr lever out and see how far it is adjusted for intial engagement. I love the way my lever feels since it dosn't let you get too carried away and the rear. I used to race motocross so too much rear brake can give be BIG problems on the street. As far as where to get the kit, It's from TYGA sports out of Japan. NO U.S. dealer carries this HRC factory part. tyga-performance.com is the site.
Pamw
Nov 9, 2008 02:24 PM
ALVINCOBRA_94
Jul 27, 2006 02:23 PM
