calis evap control
Old Jan 15, 2007 | 06:03 PM
woody's Avatar
Default calis evap control
Can any one help and tell me how to remove the smog crap of a cali 1000rr 06 i think its the evap canister and solenoid but maybe someone has a link w/ directions thanks
screw hard ride hard
Old Jan 15, 2007 | 08:03 PM
abadfish's Avatar
Default RE: calis evap control
IMHO, its not worth it unless you're doing track or racing. There won't be any hp gains and the weight savings is very minimal.
Now having said that....
I don't have a write-up but assuming its the same as a 600RR (highly likely), its quite simple. Do the following:
- remove the EVAP canister
- remove the solenoid
- plug all vacuum lines on the throttle bodies that connect to the solenoid (you can also simply plug the 5-way split that goes between the throttle bodies and the solenoid but you'll clean up the area when plugging at the throttle bodies because you'll remove all those hoses
You can also get rid of the PAIR. Here's a write-up on a 600RR (likely the same as your bike):
http://cbrworld.net/forums/thread/248171.aspx
NickLande
Jul 18, 2013 02:22 AM
Zachy72
Mar 6, 2013 11:39 AM
harris7139
Jul 24, 2011 09:29 PM
f4i_hawk
May 19, 2009 06:40 PM
rvgriff
Oct 20, 2007 08:16 PM
