best mods ???
Old Aug 12, 2005 | 07:24 AM
bowtiepwr's Avatar
Default best mods ???
>so can we do a list of of the best mods for these two wheeled powerhouses ... like a hi flo air fillter,exhaust,gear change(front and rear cogs) what else is there other than going into the engine or adding a blower,turbo,and even N2O ?
Old Aug 12, 2005 | 10:17 AM
MgA_ODEN's Avatar
Default RE: best mods ???
ORIGINAL: bowtiepwr
Best Mod - Power Commander
High flow air filter - BMC (Race) then do the Flapper valve mod
Exhaust - To many to pick from (get what you like)
Gear Change - Front 1 down Back 2 up , then get a SpeedoHealer
Old Aug 12, 2005 | 01:43 PM
Runnin1000's Avatar
How do you like the gearing with 1 down and 2 up? I just went 1 down last night so I have not riden it yet but I was also thinking about going up 2 also.
Old Aug 12, 2005 | 04:24 PM
MgA_ODEN's Avatar
ORIGINAL: Runnin1000
I wouldn't do 2 up on the rear unless you were doing the 520 conversion .
1 down on the front is the best bang for the buck.
520 conversion
Old Aug 12, 2005 | 07:30 PM
Runnin1000's Avatar
Oh yeah most def. I'm gonna stick with 1 down for now and get a power commander and see how I like it at the track.
Old Aug 15, 2005 | 10:18 PM
RepSolRider's Avatar
When you went 1 down in the front could you really tell a seat of the pants difference?? Also how did it affect fuel mileage??? Would you do it again if you knew then what you know know?
Old Aug 15, 2005 | 11:29 PM
MgA_ODEN's Avatar
ORIGINAL: RepSolRider
Yes
Not much , my mileage sucks , I tend to keep the needle above 7grand , that's just the way I ride (in the middle of the power band)
Here is a Gearing Spreadsheet (excel)
Hell yes , I've done it to all my bikes
Old Aug 16, 2005 | 10:33 AM
Anubis's Avatar
I`ve replaced the brake lines for steel braided hoses, i had a bit of fade with the original items when in constant use fast riding and track, i`d recommend this mod `cos you gotta stop faster if ya wanna go faster.
Old Aug 19, 2005 | 07:36 AM
bowtiepwr's Avatar
[quote]ORIGINAL: MgA_ODEN
>thanks needed a link like this
Old Sep 11, 2005 | 03:29 AM
Whippet Goode's Avatar
If you're actually gonna ride it, this is what I'd do first:
Woodcraft frame sliders
Puig double bubble windscreen
Arata adjustable rearseats
Sargent seat
Throttlemeister
Galfer Superbike F & R brake lines + clutch line.
Next would be a shock (Elka, Ohlins or Penske) & re-valved forks would allow you to ride faster than any other mod(s) for the same money*.
Other things like exhaust/ PC III, LED turnsignals, sprocket/chain, rearseat cowl, airfilter (BMC), flapper valve, carbon fibre can come later down the line as your buget allows.
*BST carbon wheels would make a HUGE difference, but they are very expensive & the suspension (F&R) would need to be set-up with these or they'd be off the mark.
Spend as much/more of yer hard earned dosh on riding schools/trackdays to really become fast.
Cheers
