best mods ???
>so can we do a list of of the best mods for these two wheeled powerhouses ... like a hi flo air fillter,exhaust,gear change(front and rear cogs) what else is there other than going into the engine or adding a blower,turbo,and even N2O ?
RE: best mods ???
ORIGINAL: bowtiepwr >so can we do a list of of the best mods for these two wheeled powerhouses ... like a hi flo air fillter,exhaust,gear change(front and rear cogs) what else is there other than going into the engine or adding a blower,turbo,and even N2O ? High flow air filter - BMC (Race) then do the Flapper valve mod Exhaust - To many to pick from (get what you like) Gear Change - Front 1 down Back 2 up , then get a SpeedoHealer |
RE: best mods ???
How do you like the gearing with 1 down and 2 up? I just went 1 down last night so I have not riden it yet but I was also thinking about going up 2 also.
RE: best mods ???
ORIGINAL: Runnin1000 How do you like the gearing with 1 down and 2 up? I just went 1 down last night so I have not riden it yet but I was also thinking about going up 2 also. 1 down on the front is the best bang for the buck. 520 conversion |
RE: best mods ???
Oh yeah most def. I'm gonna stick with 1 down for now and get a power commander and see how I like it at the track.
RE: best mods ???
When you went 1 down in the front could you really tell a seat of the pants difference?? Also how did it affect fuel mileage??? Would you do it again if you knew then what you know know?
RE: best mods ???
ORIGINAL: RepSolRider When you went 1 down in the front could you really tell a seat of the pants difference?? ORIGINAL: RepSolRider Also how did it affect fuel mileage??? Here is a Gearing Spreadsheet (excel) ORIGINAL: RepSolRider Would you do it again if you knew then what you know know? |
RE: best mods ???
I`ve replaced the brake lines for steel braided hoses, i had a bit of fade with the original items when in constant use fast riding and track, i`d recommend this mod `cos you gotta stop faster if ya wanna go faster.
RE: best mods ???
[quote]ORIGINAL: MgA_ODEN Here is a Gearing Spreadsheet (excel) >thanks needed a link like this :D |
RE: best mods ???
If you're actually gonna ride it, this is what I'd do first:
Woodcraft frame sliders Puig double bubble windscreen Arata adjustable rearseats Sargent seat Throttlemeister Galfer Superbike F & R brake lines + clutch line. Next would be a shock (Elka, Ohlins or Penske) & re-valved forks would allow you to ride faster than any other mod(s) for the same money*. Other things like exhaust/ PC III, LED turnsignals, sprocket/chain, rearseat cowl, airfilter (BMC), flapper valve, carbon fibre can come later down the line as your buget allows. *BST carbon wheels would make a HUGE difference, but they are very expensive & the suspension (F&R) would need to be set-up with these or they'd be off the mark. Spend as much/more of yer hard earned dosh on riding schools/trackdays to really become fast. Cheers |
