air box mod
Old Sep 7, 2009 | 12:26 PM
Big_Mitch's Avatar
Default air box mod
im new to the group and new to the honda world. ive been a zook rider most my life and just puchased a new honda. i love the way it rides and handles. just inquiring on ungrades on my '09 cbr 1000. has anyone done an air box mod to their bike yet? im already eyeing a taylor made exaust for it. any other suggestions so i can surprise these kaw, yammie and zook riders out there?
Big Mitch
Old Sep 10, 2009 | 12:37 PM
Big_Mitch's Avatar
disregard.....just found out from a local shop here in SC there is no air box mod for the 09 CBR 1000
Old Sep 27, 2009 | 07:49 AM
Redlinez's Avatar
The "flapper" mod is the one most do.
Old Sep 28, 2009 | 07:39 AM
Big_Mitch's Avatar
whats the flapper mod?
Old Sep 28, 2009 | 09:58 PM
Terminex's Avatar
Default Flapper
The RAM air intakes that are under your lights, run back on either side of the fairings. There is a "flapper" in that run of ducting on either side. By default those flappers are open, allowing air to flow through the intakes into the engine. below 5000RPM (might be 4500, I am SURE someone will correct me if wrong:-) the flappers are CLOSED. this was done (in addition to the "flapper" in the exhaust) to quiet the bike down so that it would pass emissions.
All you have to do is open up the fairings, remove the vacuum line from each of the flapper solenoids, plug the lines, and close it back up. If you are really ambitious, some have gone so far as to remove the hardware to save weight.
Real easy mod, EXCEPT for the fairings part. don't let anyone tell you different, the fairings on these SUCK, in terms of removal and fitting. HOPEFULLY it will get easier with time:-)
Old Sep 29, 2009 | 05:39 AM
Redlinez's Avatar
This set up is not the same as the 04-07's were. The flappers are OPENED by vacuum. Check the 1000rr. forum and the procedure is outlined there.
