08 gear suggestion?
Old Jun 3, 2008 | 10:50 PM
melloyello's Avatar
Default 08 gear suggestion?
my 08 1000 RR doesn't seem to have a lot of off the line grunt....i mostly do canyon riding....and local riding.....i'm thinking of changing my rear sprocket....the guy at R Cal racing say maybe go up 1 tooth......any suggestions?.....maybe i'm a whimp on the throttle i dunno....it just seems that i have to rev it higher than my 600 to get it going....i know changing the sprocket won't help me off the line
Old Jun 4, 2008 | 12:11 AM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: 08 gear suggestion?
Changing your gearing will help you off the line actually. I was under the impression that the 08's were geared down already compared to past models, i am sure someone will chime in shortly though about that. On every bike i have ever owned i found going -1 in the front to be perfect, little snappier response, and makes all the gears feel more torquey. I dont think i would waste 80 bucks on a rear sprocket to just go up 1 tooth, it wont make a huge difference. If you do -1 front that sprocket will only cost ya about 25 bucks, but if you want to change the rear i would suggest +2 anyhow to make it worth the money, and it will be a bit more noticeable. That would be very close to going -1 in the front, thats equivilant to +2.5 in the rear.
Old Jun 4, 2008 | 01:51 AM
camaro_forums's Avatar
Your 08 1krr is having grunt problems???
Wow...
I guess I'm just satisfied with my wimpy 600. Driven my brothers 06 1krr, and that thing pulls wheelies tooling along at 4 thousand rpm's doing 60...what more could you want? Damn.
Old Jun 5, 2008 | 07:35 PM
melloyello's Avatar
not grunt around 4K....starting off...i just feel as though when i'm reving it at take off the motor drops down...maybe its the slipper clutch
Old Jun 21, 2008 | 09:16 PM
tjripper14's Avatar
I went -1 up front on my 08 and its an animal now. You have to watch it though cause at about 9k in 1-3 it comes up hard if you have the throttle pinned and I'm 255lbs. I use this setup on the track and love it. I just got a pipe also and it yanks hard right out the hole.
Old Jun 22, 2008 | 12:15 AM
melloyello's Avatar
did you change the front sprocket yourself?...is it easy?.....do i have to change anything else other than the sprocket?....what about the speedometer/odometer?
Old Jun 23, 2008 | 05:36 PM
tjripper14's Avatar
Its easy to change and no you dont have to do anything else, your speed will only be off a few miles an hr. If you need help with taking the sprocket off let me know Ill send you picks and instructions.
Old Jun 23, 2008 | 07:18 PM
melloyello's Avatar
i heard there's a speedo mod or something
Old Jun 24, 2008 | 09:34 AM
tjripper14's Avatar
Its not necessary, you really dont need to change the speedo unless your making a greater change.
KidCr3nshaw
How-To: Mechanical
Mar 13, 2008 11:21 AM
cowboy from hell
Jan 14, 2008 07:29 PM
woodyracing
May 17, 2006 06:16 PM
brancart1
May 15, 2006 09:24 PM
RRip
Jul 22, 2005 11:17 AM
