Help ! ! ! Beep sound....
Old Aug 29, 2009 | 04:27 PM
GhostRideRSpeeD's Avatar
Default Help ! ! ! Beep sound....
Does enyone know what this beep sound means ? ?
When i start the engine shere is a short beep sound? ? ?
I have Honda CBR 1000rr 2008
is this something serious ?
Old Aug 29, 2009 | 08:09 PM
woogie's Avatar
yup, mine does it...normal as far as I know.
Old Aug 30, 2009 | 02:21 AM
does anyone know if this beap can mean that my oil level is lower than the normal ?
Old Aug 30, 2009 | 08:55 PM
woogie's Avatar
Is your oil level low?
Old Aug 31, 2009 | 08:20 AM
Will1000RR's Avatar
mine does it too...as long as no lights continue to stay on there shouldn't be an issue.
Old Sep 1, 2009 | 07:31 AM
yes it was by 850ml.
Old Sep 1, 2009 | 10:49 PM
woogie's Avatar
Did the beep stop after you filled it up?
Mine is not low, and it still beeps. A beep at startup would be a terrible way of alerting you to a low oil level. A light on the speedo does a much better job, and that's what Honda did.
Old Sep 2, 2009 | 12:46 PM
stoppie's Avatar
Default beep
Check to see if you have a new text message on your phone in your trunk.
Serriously, This beep sound should occur on all of our bikes, if it does not something is wrong.
When you turn the ignition switch to on the IACV (idle air control valve)operates for a few seconds by action of the step motor. These items are installed on the throttle body and control engine idle speed. A beep sound indicates the system is operating properly.
Sometimes it is hard to hear the beep as the fuel pump also turns on for a few seconds at the same time this beep occurs.
HIGHOCTANE
Jul 29, 2011 05:01 PM
michasiek
Apr 1, 2010 12:22 PM
dizzie56
Oct 9, 2008 11:05 AM
lmmck
Apr 16, 2008 03:03 PM
ampfp
Apr 7, 2008 02:22 PM
