yzf 750 project
yzf 750 project
ok had this about 5 years now , started pulling it apart straight away as I didn't like it as a fighter see pic , only paid £600 for it so was a cheap project , all run good apart from slipping clutch , started to put a r6 fairing on but was a little to small so sold all that and put the bike in the garage and it sat there till about 4 months ago , so restarted building it back up , ive fitted a r1 fairing now and a 04 zxr6r seat unit , I have rebuilt the forks as they were leaking , fitted another set of carbs as they are fitted with stage 1 dyno jet kit , k&n panel filter , high level r6 exhaust red line in make ive never heard of them but only paid £90 the the full system and its in good condition don't need the headders but may find a use for them , its had a service it runs but only on choke so will have to set the carbs up , most left to do now is cosmetic all panel are sprayed just a couple to clear coat , need to get the ss182 copy speedo wired , spray the rear wheel , new tyres , brake pads all round then I think its ready to use , did want it for this summer but its over now so will be ready to play next year , might get a couple of days this year but no point rushing now ,
all comments welcome
yeah have thought about it would be nice the extra power but you lose the six speed gear box , other way round it is fit the liners and pistons from the 1000 which takes the 750 up to 850 and it gains good bit of mid range , so might go that route if I find I need a bit more grunt , in its day this was a quick bike but would think now it would be out powered by a 600
