Project: Airbrushed widescreen
#52
I had some time to kill today, so I thought why not try to finish the windscreen! So first I went back over the black shadows. Next I added some white highlights to the top of the nose and around were I see it needed it. On the last two pictures I tried to "soften" up the area around the eye, and the snout where I had a black line there. I think it looks a lot better now, but I still need to put some bonding in those very small holes. Next I will just add the white hair for texture then spray some flat clear on it,and call it a day!
#53
I had a little time today so I started adding some hair highlights with a white charcoal pencil. I think this will be the last steps before I'm finish. As you can see the small chips in the middle, easy/and hard to fix, but I'm not going to worry about it! In the first picture I started around the mouth/ chin area. You can see it finally coming together! Next picture I continued working around the throat area, then worked up to the ears.
#54
#55
#57
