1998 cbr f3 tail light turning light trouble
I just bought this bike someone put the clear tail light and small turn signal on it. the brake light dosent light when u hit the brake. 1 problem 2 problem is that the right turn signal stays lit all the time but blinks when signal is given. is it wired wrong or what I cant find a diagram no where for this bike. someone please help thanks
You can find a shop manual on StephyGee's web site. There is a common ground connector (it's a double Green connector) for the turn signals. There should be a LightBlue wire from the right signal and an Orange wire from the Left signal.
The Tail Light/Brake light has 3 wires going to it. Green is ground, Brown is for the TailLight, and Green/Yellow is the BrakeLight. It's possible that the Brake light Switch (next to the Brake Pedal) needs to be adjusted.
tkahne88
04-09-2010 12:55 AM
