Header Gasket and Speedo bolt questions
Old 03-18-2011, 01:47 AM
DBEAU's Avatar
Default Header Gasket and Speedo bolt questions
I've got 2 questions for you folks, I'd appreciate any advise...
First off, if you remove the headers do you have to replace the header gaskets?
Second, there is a silver allen bolt on the lower right side of the speedo. Is it just there to look good? I can only assume it holds the speedo together. I believe mine is rattling and i went to tighten it and it just spun around like it's stripped or there is a nut on the back I can't see. Is it supposed to be tight. Does it do anything?
Old 03-18-2011, 09:28 PM
xtremef4i's Avatar
You must replace each header tube gasket if you want it to seal right.
I had my speedo off once a long time ago and I want to say that bolt is just for looks but its been so long I am not 100% sure
Old 03-19-2011, 08:27 AM
MadHattr059's Avatar
Re-using a header gasket is a iffy proposition. It might work, but dang! if it does leak, you will essentially have to do the job all over, AGAIN!
Don't know about the speedo issue, though.
Ern
FrankTheTank707
02-26-2012 04:56 PM
neel2008
08-31-2009 01:57 PM
cbr929guy
08-21-2009 08:39 PM
RYDINRED929
02-23-2008 05:00 PM
907hondaf3
04-14-2006 07:57 PM
Quick Reply: Header Gasket and Speedo bolt questions
