frame sliders for an 05'?
Old 03-22-2011, 03:09 PM
maineiack's Avatar
Default frame sliders for an 05'?
I am looking at an 05' 600rr and one of the first things I would like to do is get frame sliders. It looks like I am going to have to cut holes in the fairing to do so. Am I right or just seeing things. and if so is it just as simple as using a hole saw?
Old 03-25-2011, 12:24 PM
striker.2006's Avatar
yes you will have to cut hole in the fairings but it not just a simple line it up and take a stab at it you need to do a search for a thread that shows how to do this. OEM plastics are not cheap.
Old 03-25-2011, 01:17 PM
__Z__'s Avatar
April 2011 Ride of the Month
^^^ hes not a idiot...
Main check rr.net... they have PLENTY of write ups on the topic.
another good group of guys over there....
if your not having any luck lemme know and i can do some diggin for ya
Old 03-25-2011, 11:31 PM
nuttynu's Avatar
January 2012 AND 2013 Ride of the Month
yes u will have to cut holes, just did it on my 05 too. not that hard really.theres lots of way of doing it, SEARCH the thread
Old 03-26-2011, 12:28 AM
The__Rider's Avatar
Dude! I just had mine cut! If you do the right measurements you should come out on top. Depending on the size of the frame slider, a hole saw is the best way.
When you go to cut, put that blue painters tape surrounding the cut surface and then cut through. When you finish cutting, peel the tape off for a clean cut. Also, whatever the color of your fairings, the part where the hole was cut, like the inner part, I colored with a permanent black marker and it looks fantastic. Good luck!
Old 03-27-2011, 05:39 PM
maineiack's Avatar
thanks guys, I haven't gotten the bike yet but am doing research now to see what I am going to have to do.
Zachbw55
05-21-2013 02:42 PM
captain crash
05-17-2010 06:30 PM
mdfirefighter
01-30-2007 01:21 PM
hotwire
04-25-2006 01:20 PM
Quick Reply: frame sliders for an 05'?
