frame sliders for an 05'?
Dude! I just had mine cut! If you do the right measurements you should come out on top. Depending on the size of the frame slider, a hole saw is the best way.
When you go to cut, put that blue painters tape surrounding the cut surface and then cut through. When you finish cutting, peel the tape off for a clean cut. Also, whatever the color of your fairings, the part where the hole was cut, like the inner part, I colored with a permanent black marker and it looks fantastic. Good luck!
