Starting Problem
Old 07-13-2009, 11:15 PM
dgraviett's Avatar
Question Starting Problem
My bike had some old gas in it. I poured some new gas in it and it started but it wouldn't idle by it's self had to keep playing with the throttle to keep it running. Then it died and hasn't started since. I drained the gas tank and each of the carb bowls. And tried it again and it hit once. Tried starting for two days and nothing won't even hit now. Went to check the spark plugs and could not get the plugs off do you have take the engine off to change the spark pluggs?
Old 07-14-2009, 03:44 AM
catatonic's Avatar
Nope... If you still have your tool kit use the spark plug socket to get em out. The frame brace (bar above where the plugs are) is quite annoying, but you can slip the coils, tools, and plugs out behind them. The coils should unplug and pull right off, then get the socket down there and loosen them up, I used a magnet to get the plugs out.
Old 07-14-2009, 10:59 AM
dgraviett's Avatar
Cool cause i didn't want to take it off. Thanks
Assortedqtip
07-12-2012 12:11 AM
dirtyhall
04-15-2011 08:41 AM
CBRPutty
08-12-2010 09:04 PM
whtan20
11-25-2007 01:36 AM
ITZOBIG
04-14-2007 11:56 AM
Quick Reply: Starting Problem
