will a "busa R/R work on an F3?
Old 05-20-2010, 01:48 PM
KRUSHER F3's Avatar
Default will a "busa R/R work on an F3?
Will a GSXR 1300 'busa regulator/rectifier work when replacing the stock F3 R/R? The 'busa one has the five wires and looks just like the 600 & 750 R/R.
Old 05-20-2010, 03:11 PM
willduce's Avatar
id imagine its the same thing, almost any sportbike will work, helps if they have wiring pigtails coming out so you can just connect right wire to right wire
Old 05-21-2010, 05:08 AM
KRUSHER F3's Avatar
It has the wires coming out just like the 600 does.
Old 05-24-2010, 03:53 AM
bobmilkman's Avatar
Yeah, you'd have to look at the hayabusa wiring diagrams and compare the wires to the F3 diagram, then either build connectors or solder it right on. If you're buying it used, it would be a good idea test it per hayabusa manual spec to avoid problems.
__Z__
11-22-2010 12:10 PM
gooddfella
06-25-2010 04:45 PM
KenG
CBR1000F For Sale / Found
08-09-2009 05:20 AM
Quick Reply: will a "busa R/R work on an F3?
