Charging Problems
Old 12-19-2007, 04:02 PM
FoxRacin17's Avatar
Default Charging Problems
I had a regulator/rectifier put on a while back in Oct. It charged fine for a while but it started to quit charging over time and it got worse. Now the bike wont charge at all. Do the reg/rec go bad over time and gradually get worse or do they just stop working one day? I dont know what else could be wrong. Thanks.
Old 12-20-2007, 12:24 AM
pacemaker's Avatar
Default RE: Charging Problems
With the reg, it gets worse, as it degrades (although some carp it straight off).
Eventually it will fail altogether, get it seen to.
Old 12-20-2007, 04:01 PM
FoxRacin17's Avatar
k, i just got in from messing with it and it says that the battery is getting 14.?? volts while the bike is running. That is where its supposed to be right? So with that figuerd out, could anything be wrong in the charging system? I mean, its getting the required volts to charge. so why wont it charge the battery? Could the battery be at fault? It is kinda old. And its maintenance free so i cant check for water or do anything to it. What do you all suppose?
Old 12-20-2007, 05:58 PM
pacemaker's Avatar
You can get a false read with a Reg failing, wot happens is they get hot (overheat) & then start to fail. Take your bike for a quick squirt around the block, & then do the testing.
subyman1440
02-11-2012 08:19 AM
CSXfan
03-11-2010 07:38 PM
Duck187
04-20-2009 03:28 PM
Loren0420
10-23-2007 11:37 AM
SJN
10-02-2007 01:10 PM
Quick Reply: Charging Problems
