A little change..
Old 10-04-2011, 10:18 PM
YourEnemy's Avatar
Default A little change..
If any of you remember my old thread of my bodywork fab, I changed the F2 from this:
To this:
Painted and fabbed myself, this winter I decided to hold off any major projects with the supra and change up the bike a bit more. My current plans are to swap the 900RR motor in, a 954RR front end (forks, wheel, brakes, and controls), and maybe the VFR SSSA if time and money allows.
This previous Friday I made a drive to pick up a 900 motor, should only have 1,600 miles on it since the rebuild. Currently has an aftermarket clutch, polished covers, and a few other goodies.
Now all cleaned up:
Old 10-05-2011, 03:43 AM
coalminer frank's Avatar
Yes, I remember. Your gonna put the 900 motor in your F2? Please post lots of details and problems you encountered along the way. Your gonna need a wire harness also and custome exhaust.
Old 10-05-2011, 06:45 AM
JankCibberf2's Avatar
How much for your old fairings'
Old 10-05-2011, 10:21 AM
YourEnemy's Avatar
I am going to be using the F2 harness, and I am currently using an exhaust from a GSXR750 so using a random exhaust won't be a problem lol
Sorry got rid of those last year.
Old 10-05-2011, 09:45 PM
Nooooooooooooooo
Old 10-06-2011, 01:02 AM
How the heck is the F2 harness going to work with a 900 ecu? I dont know. Do the ecu's have the same plugs where they plug in to the wire harness. Maybe the ecu have the same part number. On a side note I have a stock 09 R1 complete exhaust that might work. Its titanium. If every thing works out maybe I'll put a 900 engine in my F2. Which would actually be kind of stupid since I have a 08 cbr 1000 anyway. But it would still be cool as hell.
Old 10-06-2011, 02:54 AM
RedBaron's Avatar
Hard to forget your bike it looks fantastic.
Sounds like a great plan for power and handling, Will the 954 forks be a direct fit, and what will you do with the Speedo?
Old 10-06-2011, 11:55 AM
YourEnemy's Avatar
Ill be using the f2 ecu also, I talked to a guy running the 900 in his f3 and used his f3 harness and ecu with no issues
Thanks baron! As far as the speedo goes im currently running the f4i cluster so my speedo is driven off the front sprocket with a 900rr sensor and a speedo healer. My temp gauge is a sensor from a 929 that ill also be transfering to the 900 motor
Old 10-16-2011, 01:20 AM
YourEnemy's Avatar
Got one of my pieces back from powdercoat, the frame will also be this color
And got my header in..
Old 10-16-2011, 12:18 PM
Boilerup15's Avatar
Dang, I wish I had the time/money to make my F2 look that good.
Quick Reply: A little change..
