is there easy way to set up floats
Hi All
I have revving issues with my cbr1000f-j, had some great advice from this site already, which has sorted a lot of issues out. Bike ticks over fine when in neutral it will only rev to about 7000 rpm and sounds awful, when riding it pulls clean to about 4000 rpm then shuts down, it will only pull again when I`ve changed gear and is below 4000 again. I`ve been told it could be floats in carbs, how do I check these and is there a easy way to ensure all floats are even, any help or suggestions would be greatly appreciated.
Kind regards
Pete
Kind regards
Pete
Pull the carbs and clean. Could be a blocked jet. Otherwise, when the carbs are off and the float bowl removed, angle the carbs so that the float tine is just barely touching the float valve. Measure from the float bowl mating surface to the top of the float. Float should be 9mm for UK models and 9.5mm for US models.
