seat removal
Old 07-24-2015, 09:19 PM
rickway's Avatar
Default seat removal
When I took and off the rear tail section on my CBR1000 the bar for the seat lock was not attached. So the seat is locked by the seat catch and I can't remove the seat.
Any suggestions short of cutting the seat off.
Rich
Old 07-24-2015, 09:35 PM
amacadams's Avatar
Pull up on the seat edge just enough to fit a small/narrow screwdriver or similar tool in there to push the release toward the back of the bike. The release is #12 on this linked image and is set roughly 4" or so back from the edge of the seat, parallel to the keyhole:
Google Image Result for http://images.cmsnl.com/img/partslists/honda-cbr1000f-1000-hurricane-1995-usa-seat_bighu0328f1600_82b9.gif
Old 07-27-2015, 03:38 PM
rickway's Avatar
Default Seat removal
amacadams if what you say works, I will be one happy puppy. I was ready with the reciprocating saw
to cut my seat or what ever it would take.
Thanks.
Old 07-28-2015, 08:53 AM
TimBucTwo's Avatar
I had to do that once myself.
Its best to go in from the left side using some rags on the grab rail so that you don't mar it up. Three hands would help, 1-to pry the saddle up, 1-to manipulate the long screwdriver and one to hold some lighting in there. Push the lever towards the rare of the bike releasing some pressure on the saddle so that the saddle will release.
Old 08-02-2015, 01:26 AM
Sebastionbear1's Avatar
+1
Same deal for me, I hooked a shoelace up to the pull mechanism and ran it out the back under the seat to the gearsack rack. Now I just pull that to unlatch the seat, until I get time to replace the mechanism.
Cheers, SB
Old 08-03-2015, 08:01 AM
TimBucTwo's Avatar
Make sure the 'U' part of the mechanism rod is facing down so that when the key is turned CCW it rotates rearward releasing the saddle. Its a good idea to see it working properly before installing the saddle.
Rybones
12-21-2011 07:25 PM
cody1
01-18-2006 04:35 PM
SAMCAR305
09-16-2005 10:53 AM
SAMCAR305
09-16-2005 10:50 AM
Quick Reply: seat removal
