Loose Sprocket Nuts...
Old 05-30-2013, 04:42 PM
badrhino's Avatar
Default Loose Sprocket Nuts...
So when I was in the process of removing the rear wheel to sand it down I removed the rear sprocket. Before I started to remove it I grabbed it and it would move back and fourth ever so slightly. I then went to loosen the nuts and they weren't really tight at all and barely snug. When I first rode the bike I thought there was some driveline lash and I figured maybe it was just a loose chain or something. Wow, was the previous owner a dip**** and not perform any maintenance or not tighten them to spec or what? I don't think I've ever seen sprocket nuts get loose on there own.
Anyone know the correct torque right off hand without having to look at the owners manual? Thanks
Old 05-30-2013, 04:56 PM
Sebastionbear1's Avatar
30 foot lbs Page 1-16
It is quite easy to look it up in the manual!
Cheers, SB
Old 05-30-2013, 04:59 PM
MadHattr059's Avatar
65 ft/pounds with the studs lubricated w/oil, is what the 95-98 F3's run.
I imagine yours is similar, but won't swear to it.
Ern
Old 05-30-2013, 05:27 PM
Ern
You sure that's not for the driven sprocket nut Ern?
That's 78 foot lbs on the CBR1000F
And the manual says 30 foot lbs for the rear brake disc bolt.
Cheers, SB
Old 05-30-2013, 05:49 PM
Correct Sebastionbear,
65 ft/pounds is for the driven (rear) sprocket nut(s).
The drive (front) sprocket bolt(s) is 40 ft/pounds for the F3.
By the way, Rhino...it might not be a bad idea, to get the manual
and go through the rest of the bike. It would be worth the hassle,
if you find even one more bolt/nut, that's not properly torqued.
Hope this helps, Ern
Old 05-30-2013, 10:11 PM
Sprock's Avatar
Good thing I just always tightened my front and rear sprockets to the old fashioned
torque setting of "F" as in F'ing tight which is about 22 1/2 degrees from snapping
the bolt head off or ringing the the threads. Reckon those steel cogs won't compress a
whole lot and the front one is a Sunday morning cog - "it's a floater" ..................
Old 05-31-2013, 03:38 AM
wheelnut's Avatar
Welcome Crew
if you have a bit of movment, just check your cush drive rubbers as well
Old 05-31-2013, 12:40 PM
badrhino's Avatar
Wheelnut,
I did check the cush drives and they look good. However I meant that the sprocket actually moved a little back and forth on the hub as the sprocket nuts were not tightened down good.
xd9-g19
05-03-2011 12:18 AM
flyingfree9
09-09-2010 11:35 PM
ebinz88cane
02-19-2010 08:58 PM
mickyj
07-31-2008 04:09 AM
DBEAU
07-02-2008 01:23 PM
Quick Reply: Loose Sprocket Nuts...
