Here's a new one... (cam carnage)
Old 06-20-2014, 04:52 PM
burbleburble's Avatar
Default Here's a new one... (cam carnage)
Anyone ever see the little ear on the cam where the gear attaches bust off like this? The threads on the bolts that hold the gear to the cam were worn smooth, and it let loose on the freeway. Only damage I can see besides the cam is where the teeth on the cam dug into the metal plate behind it toward the rear of the motor, amazingly the chain was still on top of the gear, so I don't think it jumped time.
Anyways, I doubt this is a common occurrence, just thought I'd see.
Old 06-20-2014, 05:10 PM
hawkwind's Avatar
EEK!
Not seen anything like that before.
Old 06-20-2014, 05:13 PM
Me either. I've put 7k trouble free miles on this thing since last year, and this is the first catastrophic thing to happen. I'm torn between tearing down the motor, or just parting it out.
Old 06-20-2014, 06:55 PM
thedrewski86's Avatar
Welcome Crew
Where are you located?
Old 06-20-2014, 07:02 PM
Conrice's Avatar
Edited.
What do you mean you're still "in-time"? Did the whole gear break free from the cam? Or is it just the one side (the one ear) that broke? If they both broke, that cam wouldn't spin - in which case nothing is in time and whichever cylinder still had the valves open must be completely destroyed, combustion chamber, valves, and piston.
If just one of the ears broke, and the cam was able to still spin, it's maybe okay. If the bottom bolt (referencing picture) is still holding the gear in place, then how warped/bent is the cam gear?
Still though, that's hardened steel. I can't believe that'd break like that - even if the bolts were stripped.
Old 06-21-2014, 08:00 AM
cb2cbr's Avatar
My guess is the bolt may have been over-torqued and/or finding a weak spot on that ear. If you don't see damage on the crank gear down below you may have lucked out and the broken ear found it's way to the crank case. If it didn't make a bunch of shrapnel on the way there it's an easy fix. Cam, cam chain, cam gear if it's damaged.
Do a compression check to see if you have bent valves, if good, press on.
Old 06-21-2014, 11:24 AM
Sprock's Avatar
Is the CCT still intact ? or did it break up and cause the carnage ?
Old 06-21-2014, 10:32 PM
wooferdog's Avatar
Burble.
You in Puyallup?
I'm in Lakewood @ the end of 512. I'll help any way I can to get you on the road again.
That's too pretty of a bike to part out.
PM Me
