help me with my 1000f 1988 changed motor
Old 06-12-2012, 10:31 PM
daniellebryce's Avatar
Default help me with my 1000f 1988 changed motor
I am having trouble and need to know if i need to change my wire harness on my 88 when changing the motor to a 90 please help it ran before the motor change
Old 06-13-2012, 05:46 AM
TimBucTwo's Avatar
No but yes. It's apparently the pulse generator that you need to modify.
Didn't want to leave you hanging but I'm heading out the door and will search for that thread when I get back. See if you can search it out before I can.
That's the direction you need to go.
Edit: I'm still looking for the thread on the swap but found that PMCG [link] did similar swap. You may want to PM him.
Old 06-14-2012, 05:10 PM
hawkwind's Avatar
This may be the thread TBT was referring to. Though I think it's the other way round for you. Harry was putting a MK1 engine into a MK2 bike.
Old 06-14-2012, 08:17 PM
pmcg's Avatar
I ended up just using the newer head so all of my electrical was still 87/88. I know that the 87/88 loom has a fuel pump and a fuel pump relay in it that the 90 will not. I am not sure if this will be an issue or not as the fuel pump and relay are on the same circuit as the ignition. When I get home I will look at the connections from my 95 bottom end and let you know if they are the same as my 87.
Old 06-15-2012, 10:27 AM
TimBucTwo's Avatar
^ I think I remember a thread where the pulse generators were different, one vs two on the newer engine. I can't remember the final fix. I don't remember if you were in on that discussion.
Old 06-15-2012, 01:34 PM
I have purchased and 7 pin rotor and double stator from an 87 the 1990 had a 9 pin rotor and single stator when it gets here i will let you know how it worked, if it did of course. Also I think I read something about being able to put an even newer motor in my 88 is this true and how can I find out what works??
Old 06-15-2012, 01:36 PM
Sprock's Avatar
yep all cbr 1000f motors from 87 to 96 (99 Euro) will go in
Old 06-15-2012, 01:49 PM
hawkwind's Avatar
Forgot to put the link up! Here it is :- https://cbrforum.com/forum/cbr-1000f...-plugs-123295/
Old 06-15-2012, 03:01 PM
pmcg's Avatar
I have a complete bottom end from a 95 let me know if you need anything off of it.
Old 06-18-2012, 09:36 PM
OK just so everyone knows if you change your 88 to 90 you must change the rotor and stator to the 88 style took 5 minutes fired right up little fine tuning to do and ill be on the road needs some tlc to look good but ill get that done too I want to make it look BAD anyone seen anything out there for fab ideas?
Quick Reply: help me with my 1000f 1988 changed motor
