Help to clean carbs on a Mk2 please
Old 12-19-2014, 11:02 PM
rickway's Avatar
Default Help to clean carbs on a Mk2 please
Re: '93, CBR 1000F. After 45K of crappy gas, and the engine running on 3 cylinders, it's carb cleaning time. The manual says remove air box, but it won't get past the frame. Now to remove the carbs. Any tips? Winter or not, I want to ride.
Old 12-20-2014, 02:43 AM
Shadow's Avatar
Here's a list of all the "how to's in the 1000F section.
Sure to find what you need.....
How To's - Page 2 - CBR Forum - Enthusiast forums for Honda CBR Owners
Here's one on sync'ing
http://www.thestraycat.net/CBR_Farkles.htm#Carb%20Sync
Here's a Honda generic - courtesy of our local troll
https://cbrforum.com/forum/how-mecha...r-carbs-40713/
Let us know if you need more help.
Old 12-20-2014, 09:48 AM
Sprock's Avatar
In short the airbox when unbolted will pry rearward far enough to get the carbs out.
If you take the fuel bowls off plan on replacement oring gaskets
Air needles and pilot jets are a must along with a good tank cleaning.
Any rust particulates usually mean sealing the tank to stop rust infiltration
to the carb pilot jets.
Old 12-21-2014, 10:54 PM
Jlaz's Avatar
I have a 1990, I needed to do a deep clean, so I broke the bank and removed all rubber and plastic from the bodies. I then boiled them for 10 min each in some Pine-Sol.
Also, I boiled my jets and needles, do not forget any fuel or breather tubes, or the pilot screws, these both have o-rings and will be ruined if boiled in the Pine-Sol.
I used water to clean the residue off and then some compressed air to dry everything, then a quick blast of some carb cleaner.
Take plenty of pictures if you decide to go this route as getting the bank back together can be tricky.
Any time you reassemble a bank of carbs you will need to re-sync them.
816_wallace
06-13-2012 03:19 PM
el bimbo
11-01-2008 11:47 PM
motodaddy
03-20-2007 03:11 AM
123svt
07-19-2006 09:52 PM
Quick Reply: Help to clean carbs on a Mk2 please
