Fuse question
Old 09-30-2013, 04:17 PM
catworst's Avatar
Default Fuse question
Can anyone tell me if the fuse for the rear light/brake is also for the headlight?
Cheers.
Old 09-30-2013, 07:20 PM
Sprock's Avatar
horn, brakelight , turnsignals are together not the headlight
Old 10-02-2013, 12:02 PM
catworst's Avatar
Thank you for that. I'm having big problems with my rear light, I've no power going to the wires for either brakes or light. I know that's vague but any suggestions?
Old 10-02-2013, 02:03 PM
hawkwind's Avatar
Check the bulbs, then trace the wiring back from the rear light checking for power at all connections, that way you'll be able to isolate the fault.
Old 10-04-2013, 08:42 AM
catworst's Avatar
Thanks for that, it's in the back of the loom somewhere. Any idea if the loom if the loom it's the same on an89 as it is on my 88?
Old 10-04-2013, 09:24 AM
Sebastionbear1's Avatar
Not sure about that as the '88 has the fuel pump back there and the '89 doesn't. Everything else at the rear should be similar.
Cheers, SB
Old 10-04-2013, 10:00 AM
Sprock's Avatar
Not same, could be made to work, but easier to just grab a harness from an 89-91
smoorebmw
08-10-2011 06:11 PM
newnut
05-16-2008 01:25 PM
alesser738
06-27-2007 01:52 PM
mike70845
08-03-2006 01:42 AM
ox.
05-26-2006 12:13 AM
Quick Reply: Fuse question
