a bit of time off
Old 10-02-2015, 01:58 PM
wheelnut's Avatar
Welcome Crew
Default a bit of time off
just had another week off, so I thought I would rebuild the front brakes and fit braided line
a stuck piston removed with my insert puller
removed seals and a clean with the dremmel
new pistons
braided lines
best £15.00 I have ever spent, makes short work of filling the callipers and lines with fluid, then bleed in the normal way, I usually pump the lever a fair few times and tie back and leave for a few hours and hopefully if there are any bubbles left they rise to the resevior
Old 10-04-2015, 01:02 PM
bullroarer's Avatar
Hi Wheelnut.
Cant beat having the right gear. If I do the same job, and Im without the kit you have, I fill the caliper up with fluid with a cheap syringe, then put the brake lines on then fill the resivior up. Bleeding those bleeding brakes is a doddle.
Old 10-05-2015, 04:38 AM
wheelnut's Avatar
Welcome Crew
yep I have done it the same way, the syringe makes life easier, I take it with bleeding we have all learnt the hard way, at least I know I did
STREETFIGHTER88
10-30-2010 03:37 PM
odysseyzray
04-06-2009 10:09 PM
Draco88
09-28-2006 06:39 PM
Draco88
09-10-2006 10:52 PM
Quick Reply: a bit of time off
