anyone know what the 3 way joint connector for the radiator tubes is called?
Bike = 90' Hurricane CBR 1000
Problem = dry rotted 3 way coolant hose connector peice (coolant was leaking then I took it apart and it litteraly just fell apart!)
Details: Does anyone know the proper name OR where I can find the 3-way coolant hose connector which is located underneath the right handle bar under the coolant cap peice im referring to? I'll post a pic if needed tomorrow if no one knows, but it sucks with my phone.
Also at www.mrcycles.com
I don't know it's proper name, but I gave it a few new ones when mine broke !!! :eek"
Mr Motorcycle
Shadow,
I see you're listed as being in South Africa. So I have to wonder where Mr Motorcycle is if you are ordering from them or do you NOT order from them? I had been getting OEM parts from Bike Bandit in California. I need to replace some rocker arms in my GB and I see that MR MC is significantly cheaper. I'll swithch suppliers if they're in the US.
Mrcycles.com are in the US Bassman.
It's cheaper for me to buy everything for the bike overseas, because the local agents are
1 Useless
2 Overpriced by 100% minimum
3 Everything comes from Japan and takes 3-5 weeks.
I even buy spark plugs from Ireland because it's cheaper than over the counter here
1 Useless
The 3 way connector on left side of bike right beside the stator regulator is called a water joint I ordered mine from partzilla . I know your 3 way is on right side of bike up at top of radiator but maybe called the same . I can’t replace my part without dropping the engine
