Disconnct servo motor
Old 10-14-2016, 12:19 PM
nytrozula's Avatar
Default Disconnct servo motor
The install instructions say to disconnect the cable to the servo motor before I install the Yoshimura RS5 slip on. What does this motor do and what would happen if the cable was not disconnected? Can the stock muffler be used with the cable disconnected?
Old 10-15-2016, 09:33 AM
Conrice's Avatar
The servo motor operates a butterfly valve in the exhaust. You're deleting that part of the exhaust. So - you need to take the cables out and leave the servo motor wiring connected so the ECU still thinks it's there. You can also buy a "servo buddy" which allows you to delete the servo motor all together (it's what I've done).
Old 02-17-2017, 03:15 PM
Stephens's Avatar
I removed the entire assembly when I put my Two Bros pipe on.
EndoEd
07-10-2008 09:03 AM
SFR929
06-17-2006 04:08 AM
00Red929
05-17-2006 05:12 PM
dave954
05-07-2006 08:38 PM
brandon
05-09-2005 12:06 AM
Quick Reply: Disconnct servo motor
