ignition coils do not spark
Old Yesterday | 02:34 PM
juri23's Avatar
Default ignition coils do not spark
Hi, I need some advice, my CBR started worse when cold and while it was running it choked in places + black spark plugs. I thought it was a faulty fuel pressure regulator, but after measuring the regulator the regulator is ok. Then I started measuring the individual MAP, IAT and fluid temperature sensors according to the workshop manual. The connectors from the controller were disconnected and they were measured. *I measured one pin on the controller with a meter against the ground* after reassembling the bike it didn't start anymore - the reason is that not a single ignition coil gives a spark. My question is, did that one measurement set off the controller??? Or is it blocking the HISS. The starter turns, the pump delivers fuel, the instrument panel doesn't write any errors but the coils simply don't give a spark. Thanks for the advice
Motorcycle CBR 600F, 2001. EU version, PC35
tampa_git
F2 Tech
Oct 18, 2022 11:09 AM
forestfarm
Nov 18, 2021 04:40 PM
GPiper
F2 Tech
Aug 6, 2013 08:38 PM
sk8er406
Nov 7, 2011 07:58 PM
Nate
Mar 15, 2007 02:06 PM
