West AK, CA, NV, OR, UT, HI, WA, ID
Bleeding brakes
Old Feb 23, 2009 | 01:22 PM
dennis1er's Avatar
Default Bleeding brakes
Whats up everyone. This past weekend I change the front and rear brakes pads on my bike. Everything went a-ok actually it was pretty easy.. I need to bleed my brakes and dont know how to do it can any please help me?? how do i bleed my brakes..
Old Feb 24, 2009 | 09:20 PM
JOECBR600F4i's Avatar
Do yo have a brake bleeder pump? Easiest way to do it. Also a second person helps. Basically just like a car, pump brake lever, build up pressure, hold lever closed then release bleeder screw and let air out of caliper. Close bleeder screw before lever goes all the way down to prevent air from being sucked back in. Repeat until you have firm brake feel and not air bubbles in master cylinder.
DO NOT LET MASTER CYLINDER GO DRY or it will pump air into the system. Hope this helps.
Old Feb 25, 2009 | 09:38 AM
dennis1er's Avatar
Thanks i did not know i should close the screw before it goes all the way down..i just took care of it and its good to go.. i tryed to do it by myself too and did not work.. thanks again
fireblade00
Apr 22, 2009 02:06 PM
Jadyone2
Apr 22, 2009 11:09 AM
stunter411
Nov 2, 2007 11:40 PM
malik987
Sep 17, 2007 10:25 PM
Ricepowered01
Oct 26, 2005 12:02 PM
