TRG Coating TRG Coating is a small shop specializing in custom powder coating, batch powder coating, thermal barrier coating, and much much more. Our areas of work include automotive, motorcycle, ATV, marine, medical, and even lawn furniture. Basically, if it's metal, we will coat it for you with the proper formulation and the correct process.
Gas Cap ???
Old Feb 26, 2008 | 10:42 PM
Carbon_cavvy's Avatar
Default Gas Cap ???
If this can be coated what is done with the seal that seals the tank ? can it be removed or replaced ???? Im sure you guys have dealt with this, the seal on mine might be buggered..... figure you guys would know....
thanks TRG !
Old Feb 27, 2008 | 11:24 PM
TRGcoating's Avatar
Default RE: Gas Cap ???
they can be done but youd have to take it apart and theyre pretty complicated
Old Feb 29, 2008 | 01:17 AM
camaro_forums's Avatar
Blue Fox did it, right? So it can be done
