TRG Coating TRG Coating is a small shop specializing in custom powder coating, batch powder coating, thermal barrier coating, and much much more. Our areas of work include automotive, motorcycle, ATV, marine, medical, and even lawn furniture. Basically, if it's metal, we will coat it for you with the proper formulation and the correct process.
bolts
Old Jan 18, 2008 | 01:30 PM
rdrink25's Avatar
Default bolts
how much per bolt and does is change the size so much that i would not be able to get an allen wench in to fit i am looking to do about 50 bolts
Old Jan 20, 2008 | 07:19 PM
TRGcoating's Avatar
Default RE: bolts
Bolts i usually charge about $1 each. WIth an allen head shouldnt be a problem, its hex bolts etc that there would be a problem.
Old Jan 21, 2008 | 09:25 AM
CBR1000's Avatar
Default RE: bolts
ORIGINAL: TRGcoating
So if I sent you my passenger pegs and bolts you can coat the factory bolt heads and the powdercoat wont cause any problems with the allen wrench fitting into the bolt? Seems like it would fill in the space or chip off when you reinstall?
Old Jan 21, 2008 | 10:11 AM
TRGcoating's Avatar
Default RE: bolts
Should be fine, might need to force the allen key in a little. When i do bolts i go a little thinner. I have done a bunch for customers with no problems...only hex heads cause problems.
BakaN20
Apr 12, 2011 12:08 PM
bdahl77
Jun 8, 2007 04:02 PM
Jaybird180
Feb 17, 2007 02:04 PM
acanz
Jul 25, 2006 07:04 PM
prkinlotF4i
Dec 12, 2004 04:29 AM
