TRG Coating TRG Coating is a small shop specializing in custom powder coating, batch powder coating, thermal barrier coating, and much much more. Our areas of work include automotive, motorcycle, ATV, marine, medical, and even lawn furniture. Basically, if it's metal, we will coat it for you with the proper formulation and the correct process.
06 600rr clutch cover
Old Jun 12, 2007 | 09:55 PM
rdrink25's Avatar
Default 06 600rr clutch cover
I am in need of help I recently powder coated my clutch cover there are 2 bearings inside there one on top and the other is right below. my local honda shop has said that the lower can not be replaced because the can not remove the lower bearing now i know for sure that the bearing can be purchased i just dont know if anyone has actually pulled it out then put it back in.
thx
estate4life
Jan 15, 2009 11:59 PM
89cane
Jan 7, 2008 07:33 PM
