Teaser... Wheelie Machine is nearly done...
ORIGINAL: TK954RR
ROFL Pix. Looks awsome though, cant wait to see the vids. So do us CBR members get half off per hour when we come to use it
lol.
No, I'd hook you all up.
Spent 2 hours today taking the entire thing apart to take the drums to my machinist and get them diamond knurled for the traction I need.
I'll keep ya updated!
- Pixel -
ORIGINAL: Gville George
does it adjust for worn/different tires?
So the system is designed that I can make an axle even if the swing arm on the bike is 3" narrower, or wider than on my 929. I set up the system initially so that a 190/55 wheel (usually used for racing, 190/50 is more common) is at roughly the top point of adjustment.
I can then apply about 3" of travel on the axle downwards... meaning on a 17" rim, I can pretty much put the rim in contact with the drums. So again yes.
The drums are both independently adjustable, either closer to or further away from each other. So I can also make even additional adjustments there. But wait! There's more! On the exhaust side, I can remove the slider plate, and lower the exhaust side A-frame and additional 1/2" in case someone's exhaust sits too low.
Trust me, I gave adjustability a lot of thought in my design.
Today I went and spent yet again more cash on climbing gear so that I can quickly make the height the bike will wheelie adjustable, and repeatable. So from say a shorty 2' wheelie, to the wheels at 12 o'clock.
Even sicker in my safety strap design, is 2 webbing straps that have bungee cords inside them, so that if you end up needing the safety straps, they will hit the bungee cord anywhere from an adjustable 6 inches to 2 feet before the main straps catch the bike... suppressing the jolt a bit as you rely on the cables. Like the rest of my design, the safety system is redundant, and independent of each other. The 2 systems also mean that the front tire should be able to come to a rest on the springboard ramp without putting the webbing between the tire and the ramp. Just 1 on either side, with the slack being helped to pull out of the way with the bungee cords. Should be sick.
Well, here's the pics from this part of today's project.... the diamond knurling of the drum. God I spent too much money today lol. But this should fix my issue of traction no problem, and actually allow me to loosen how much down pressure the tire needs on the drum.
so... any more questions? lol. I so babble.
- Pixel -
I got another, since you are using actual dynos for this, does that mean you can still measure HP with them? in that case you could measure how much horse power your are using to get the front end up.
Take it in...
Wheelies... but needs some tweaking to feel right. Tire hooks up good now, but the fly wheel makes a 1st gear clutch up feels closer to a 3rd gear clutch up. But I have some ideas on how to make adjustments.
I'll post some more info, and more questions in a bit.
- Pixel -
- Pixel -
Damn Pixel, lookin good! So are you going to carry diffrent axles for diffrent common bikes with the unit so customers can just change out on the spot or are people supposed to beat your bike?
ORIGINAL: Northernfirepower
And to answer the other post... yes, other people have made these machines... I'm not the first. It's just something I wanted to do myself. And compared to the other designs I've seen... Mine should be safer because of the way the axle mounts, and the redundancy of all the possible fail points. For example.... the quick release pin that allows the top adjuster screw assembly to be held in place, has a double sheer fail point of 20,700 lbs... and there's 2 of them. Things like that.
- Pixel -
