Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
stuntin
Old Aug 1, 2007 | 11:29 PM
TheDouche's Avatar
Default stuntin
haha well all i gotta say is that im a small guy and i eventually want to be able to do a high chair?(thats when you sit on the tank and your feet are on the lights basically right?) now all i gotta say is that it takes a lot of muscle and muscle control to do all this. does anyone have like a workout that they do to build the muscle better for stunts or what the secret to high chairs? still perfecting the balance point thing so im not gunna be trying this for a while until i am ready
Old Aug 1, 2007 | 11:59 PM
twistatech's Avatar
Default RE: stuntin
First you have to dent your tank, Then you should buy a hand brake, do a couple push ups and pull ups and you should be able to do it.
Old Aug 2, 2007 | 01:20 AM
TheDouche's Avatar
Default RE: stuntin
hand brake? do explain
Old Aug 2, 2007 | 09:29 AM
civiksi's Avatar
Default RE: stuntin
ORIGINAL: TheDouche
Hand brake for the rear brake. Dont think you'll be able reach the rear brake from the gas tank.
Old Aug 2, 2007 | 08:45 PM
TheDouche's Avatar
Default RE: stuntin
hahaha why would you need that? just slow down in throttle haha. any advise though as far as high chairs go?
Old Aug 2, 2007 | 09:07 PM
CBRollie1000's Avatar
Default RE: stuntin
yah just use the front brake and that will be another stunt the LOW chair haha. j/k
Old Aug 2, 2007 | 10:37 PM
twistatech's Avatar
Default RE: stuntin
Did you dent your tank yet? Because if you try a high chair w/o it dented, you will dent it with your ***, that is if you even stay on the tank when you land. Also you might want to have a hand brake, if you go to high in a highchair you will end up doing a trick called the hospital bed.... but if you insist on breaking your back , sit on the tank and get both legs over the bars, get going about 25 and clutch it up. all there is to it...
Old Aug 3, 2007 | 12:21 AM
TheDouche's Avatar
Default RE: stuntin
so where does the extra hand brake usualy go? or do you swap it front hand brake works rear tire and foot brake works front tire? im not gunna be attempting a high chair yet but it would be nice to know what to do and expect. where do you dent the tank or do i just wait to dent it when i pull it off? haha low chair lol.
Old Aug 3, 2007 | 12:44 PM
twistatech's Avatar
Default RE: stuntin
The extra hand brake goes where your clutch is now, then you get a shorty clutch and put it on top of your new hand brake lever for the clutch. One of these guys probably have a picture of a hand brake set up but I found a couple too here they are...http://www.flickr.com/photos/jorge_180801/438466149/ & http://www.flickr.com/photos/beadyeye/454637028/
You are going to have to dent your tank when before you try this, otherwise you will not stay on. Here is some pictures of a guy that dented his, I put skateboard grip tape on mine for extra grip. Plus my tank dent isn't quite that big. But I guess it depends on how big your *** is. You have to get a dead blow hammer and pound away, there are probably some posts on here about how to do it. This guy ground his paint off and used bondo to make it smooth. I just dented mine and put some grip tape on there and called her good... here is the post on stuntlife with the pictures... http://www.stuntlife.com/forums/281-...nk-dent-2.html
duececivic
Sep 23, 2009 10:19 AM
ZDUB
Aug 18, 2008 08:45 PM
DDCavi
Dec 27, 2007 01:25 AM
CoreyAkaOpie
Apr 8, 2007 05:01 AM
BlindLOKI
Feb 1, 2006 09:35 PM
