Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
stand up wheelies
Old May 2, 2009 | 09:44 PM
joshuaswift's Avatar
Default stand up wheelies
when doing stand up wheelies how do you keep from veering to the left or the right???
Old May 3, 2009 | 12:10 AM
johnnyh's Avatar
Lower your air pressure to about 15 pounds.
Old May 23, 2009 | 02:36 AM
stunter411's Avatar
Air presure does not have to do that mutch. Its all u how u position ur self. Dont shift ur weight from one side to another and ull be good.
Old May 24, 2009 | 06:21 AM
MuSiC's Avatar
exactly what stunder411 said.
Old May 28, 2009 | 06:45 PM
f3BikeR's Avatar
..but tire pressure does matter.
A rear with 20psi WON't want to steer like one with 40psi.
Practice with 20psi and then bring it up as you learn how to steer your standups.
Old Jun 26, 2009 | 09:49 AM
Stay2ned's Avatar
Lowering your air pressure will make it easier but it's not necessary. Keep your knees bent slightly and position your body according to where you're leaning. If your bike leans left, turn your bars left and lean your body right. Turning your bars allows you to get over further to straighten the bike back, just make sure to straighten em before you bring it down! Tank slapping is not fun, trust me. Good luck with em, keep your gear on.
Old Jul 10, 2009 | 12:45 PM
Compton82's Avatar
Being smooth on the throttle will also keep the bike from wanting to move around on ya
Old Jul 10, 2009 | 01:44 PM
nickels's Avatar
I Can't Sell On CBRF
hit the nail on the head.......lower pressure is for learning slow wheelies...lower pressure on the streets will give you a wobble and be hard to steer....i learned some stuff on 12 lbs of air in the rear but now i run about 30 lbs all the time, streets or lots...it will end up goin to 35-40 when i get better
Old Jul 13, 2009 | 12:13 AM
TK954RR's Avatar
Jan 2009 ROTM
balance, ive never had an issue and i run 35 psi all the time. Imo as stated it makes it much more difficult at low speeds, but above say 40mph you should not notice. If your having that much of a problem its likely your balance, rear wheel alignment, or your not high enough.
Old Jul 13, 2009 | 03:33 PM
xjoewhitex's Avatar
Will that also help the tire bite? Ive been also trying to learn a bit and at times I have some wheel spin.
