Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
endo flippo, no start now
Old Aug 15, 2007 | 06:19 PM
Foght's Avatar
Default endo flippo, no start now
A budy of mine endoed his f4i last night doing a stoppie. it was perfectly upside down for 2 minutes or so. (resting on the handlebars and seat)
now it wont start. the fuel pump primes, so i don't think it is the tip over switch, or BAS. we tried to start it, won't turn over. tried push starting it, locked the wheel in every gear.
the compression is super high, like 300!!
any ideas?
Old Aug 15, 2007 | 07:07 PM
Err's Avatar
Err
Default RE: endo flippo, no start now
got spark?
Old Aug 15, 2007 | 07:14 PM
Foght's Avatar
not sure. any other ideas? i'm lost on this one.
battery power wont turn it over due to the super high compression. so i can't test the spark.
Old Aug 15, 2007 | 08:22 PM
TK954RR's Avatar
Jan 2009 ROTM
how did you manage to test the compression if you cant turn over the motor?
Old Aug 15, 2007 | 09:30 PM
DThompson's Avatar
^^^ Ya???
Old Aug 16, 2007 | 05:16 AM
Foght's Avatar
starter won't turn it over. had to turn it over by hand. (rotate the crank with a big breaker bar)
Old Aug 16, 2007 | 10:44 AM
Northernfirepower's Avatar
Do you have the tip sensor jumped? If so make sure it is still jumped
Old Aug 16, 2007 | 12:37 PM
DDCavi's Avatar
Oil in the cylinders?
Old Aug 16, 2007 | 08:20 PM
Foght's Avatar
it was oil in the cylinders. took forever to ge tit out.
smokes like a freight train now. i'm sure it will 4 a while!
Old Aug 17, 2007 | 02:00 AM
Vermino's Avatar
ORIGINAL: Foght
that's true balling.. now when you stunt, you can try to do smoke clouds or write your name out with your exhaust smoke muhaha.. i hope it is a stunter and not a daily rider..
