Starting my first F3 Street Fighter Build
As far as tail conversion, it depends on your skills. What fab skills do you have. How are you with a grinder? Can you weld?
That determines what tails you can do (let alone what ones look best) and then how much it will cost?
Look forward to seeing the new headlight and cowl
If he can weld, he can weld the sub frame - it doesn't matter if he knows motorcycles or not. There's a million "how-to's" on tail conversions. With the steel frame of the F3, it will be very simple. If you can weld the rear, then you can do any tail you want.
Decide, and plan. That's all you need to do.
Yea ive been checking CL every night but yea I buy everything off eBay but that's gonna be costly to find all the parts for the rear end
It wont handle as quick.
The rear will have less traction.
You'll need a stiffer spring (because of the added leverage on the rear softens up the rear suspension).
Obviously, you'll need a longer chain too.
But, if you want to do it, have at it, man.
