Headlight trouble
Hi all, I have a 1998 f3 fighter with a buell blast 7" light with upgraded internals (for easy/cheap bulb replacement and more versatility) and I keep burning out bulbs, I am running sylvania silver stars and and every time I pull a wheelie it burns out as soon as the rpms get up around 11 ish, but the weird part is, that when I just run it up that high or higher with both wheels on the ground it's fine. Is there a reason for this?
how is it mounted? i had an issue with my v-rod headlight. it ended up having too much vibration. i would blow under HARD braking or HARD acceleration (headshakes and the occasional wheelie). 2 rubber grommets later and it was solved.
^^^Conrice post up a pic of that avatar!!! I wanna see it! lol sorry for off topic,
Anyways, it might be a grounding issue that high rpms cause vibration and loosen the wire and sends to much power which = blam! |
Originally Posted by JankCibberf2
(Post 1102202)
Originally Posted by Conrice
(Post 1101848)
sorry to hear about the mishap. mine's just aluminum stock from ACE.
