Boxdgm's F1 fighter build log
Old Mar 31, 2012 | 01:57 AM
Boxdgm's Avatar
Originally Posted by JankCibberf2
Gaahhhhh!!!!! This looks sooo good!!!!!!!
Thanks man i need to cover up that crappy yamaha logo though haha.
I got the back wheel primered and got a coat of black on it but its pretty cold out so im going to see if the weather gets better this weekend before i spray any more paint on it.
Old Apr 3, 2012 | 01:10 AM
Boxdgm's Avatar
I started drilling the triple clamp for the ignition but snapped a drill bit deep inside the hole i was drilling so i decided to go a different route for now. I mounted the vapor gauge to the ignition loop and i relocated the ignition switch to the frame on the left side.
Got the dust seal and now with the spacer under the lower bearing the steering stem fits great. Just waiting for the spanner nut and washer i ordered from yamaha then i can finally get this thing back on 2 wheels. They said it will be in tommorow so if all goes well ill be able to ride it soon.
Old Apr 3, 2012 | 11:32 PM
Boxdgm's Avatar
Finally got the front end in. still have to finish up the small stuff tommorow but its back on two wheels again.
Old Apr 6, 2012 | 03:33 PM
Boxdgm's Avatar
Got it rideable now and wow these brakes are awesome. Had a little mishap because one of the crush washers i used on the brake master cyl was slightly too big and was slowly dripping brake fluid out. I drove it about 60 miles and didnt realize it was spraying in the wind all over the right side of the tank and ate the clear off.
Old Apr 26, 2012 | 04:40 PM
campos_motorsports's Avatar
hey, I've been looking at your progress, looks awesome, I was interested in the 600rr tail you mounted, I am wanting to do the same thing but dont know what is needed, I am mechanically inclined but wouldnt know where to start, I've read other conversions and I believe you have to get the subframe as well, but how did you approach it, thanks for sharing some info.
Old Apr 28, 2012 | 05:42 PM
Boynton's Avatar
Looks good! I hope u can get rid of the Yamama logo from your trees. I had a regal stolen from me once, they replaced the the steering wheel/ column with a Monte Carlo one. Every time I looked down at it I wanted to smash something. Wouldn't want u to go through that
Old Apr 29, 2012 | 07:08 PM
Boxdgm's Avatar
i used the stock subframe and just built brackets to adapt the tail to it. This was pretty easy and everything bolts on so i could always remove it and switch to stock if i wanted to ride 2 up if i ever wanted to.
Theres another bracket in the back but i dont have pics of it.
You need the tail, seats, side panels, taillight and front and rear latches for the rear seat but all of it can be had cheap on ebay.
https://cbrforum.com/forum/cbr-600f-...-115495/page3/
This guy took a lot better pics than i did but you can get a good idea of what needs to be done.
Old Apr 29, 2012 | 07:13 PM
Boxdgm's Avatar
Started working at a new job so havent been able to ride too much let alone do anything new to it but i did take some pics on my last ride.
Old Jul 23, 2012 | 09:10 PM
Boxdgm's Avatar
Finally dropped the parts off to be painted. Should be getting everything back in a few days.
Old Jul 29, 2012 | 03:44 PM
Boxdgm's Avatar
Got the parts back from paint, been so busy with work that i havent been able to get it all back together yet but heres a pic showing most of it back on. This color is a little lighter almost an aqua blue. I liked the old color better but at least it all matches again and the new color is growing on me.
