Here is another video from me.
Hey guys, got my helmet on. I had to reduce the quality for it to fit on putfile. About halfway through I run it to 150mph. Couldn't get below windscreen due to camera.
The other one is a 53 second clip of high speed.
http://media.putfile.com/Lower-quality-tank-Cam 9 minutes
http://media.putfile.com/High-Quality-High-Speed-Run Short Clip
right on man....looks like your having fun, however I wanted to let you know, that spot on the tac. that turns red is called the "Redline" lol You should shift before you hit it! That sound is the rev limiter kicking in! [8D]
I've said it before, but work on getting them up higher so you don't run out of rpms so quick. And also don't ride it to the limiter and slam the front down, your gonna be replacing fork seals if you keep that up. Get them up higher and when you want to set them down ease off the throttle and then get back on it a little and set it down, not slam. I'd go out and make a vid, but you guys don't wanna see a whole vid looking at the sky
-Jesse-
-Jesse-
