Front tyre came off while riding!
This is the reason I do all of my own work on my bike so I know its done right.
Tires do not require any sealant to set the beads against the wheel. It looks to me that this shop used too much of some type of soap and this did not allow the tire to seal the bead against the wheel or depending on the tools they used to change the tire they may have damaged the beads on the tires. I change my own tires and I use some soap to get the tire on the wheel then I wipe the bead down clean before setting the bead of the tire. If the wheel is straight and the bead set correctly it should be nearly impossible to have an air leak around the bead.
I have always used Windex. Windex will also show any leaks. I agree that sealant is not necessary. The shop should have used some kind of lube and if they did they should have seen the leak (if not heard it sizzling). If they did not use a lubricant, than that is shabby workmanship. You need a lubricant to set the bead properly.
Either they didn't seat the tire properly or the rim was already damaged. Both are the mechanic's responsibility to catch.
If the rim was damaged, they should have informed you and refused to work with that rim.
good point, well since i posted this thread up the tyre hasn't seemed to lose any more pressure. But I really need a digi pressure gauge to tell for sure, but it feels the same so hopefully let just hope with it being a new tyre that it has just needed to be stretched in... Could this be the case now its sealed??
A friend of mine has a no-marr tire machine that we use to change tires all the time. It is a good practice to clean the rim during the change and use a lubricant to help seat the tire. It is actually air pressure that seats the tire. It "pops" onto the rim. I usually bounce the tire a few times and then set the correct air pressure. Once I remount the tires I check the pressure again.
Ok, so I tried pumping my tyre up again tonight and the result was, the more air I pumped in, The faster it came out. Also when I pres down on the handlebars you can hear it coming out. It seems like it's just not sealing right
Did the shop put the correct size tire on your bike? A tire installed properly and the beads set correctly should not leak this bad.
Backdoc, yes the tyre is the correct size because it's one of only two types of tyres that fit on the CBR 125 (the other being bridgestone battlaxe).
But anyways I fixed the problem anyways.
I pumped it up over pressure and went out for a ride and the bead has settled it's self down nicely and there has been no more air leaks for a few hours ( indicated by my new digital pressure gauge - bought today hehe)
Thanks to all who replied anyways to try and help fix the problem, Cheers guys. Tom.
