Riding Gear Questions and reviews about jackets, helmets, gloves, etc.
Sidi Vertigo Air
Old Aug 29, 2007 | 03:00 PM
CBRYDR's Avatar
Default Sidi Vertigo Air
Hey guys,
I recently picked up a pair of the Sidi Vertigo Air boots and had a question about fitting. So from what I notice is that Sidi normally half sizes except between Size 10 and 11. There is no 10.5. It jumps from a 44 EURO to a 45 EURO. The thing is 10 is too tight and 11 is a bit loose (works better with double tube socks)
My question is how are these boots supposed to fit? The Size 10's gave me a super snug fit around the ankle but pressed too hard on the top of my big, index, and middle toe (where it's susceptible to corn). The 11's have a great fit around my feet and toes, but the ankle is not as snug as the 10's (still snug though with double tube socks). I probably can't return the 11's since I already wore them but was wondering if there is a special sock for this situation. Thanks!
Old Aug 29, 2007 | 10:02 PM
tomc1965's Avatar
Default RE: Sidi Vertigo Air
You can always cut the foot out of a pair of tube socks if needed. Or will the boot fit over your pants???
Old Aug 30, 2007 | 10:13 AM
CBRYDR's Avatar
The boot fits over my pants snug. My calves arent that swoll so they don't fit snug in the boot. When I put the boots over the pants, it's a perfect fit. Since I'm a new rider, I don't want it to look squidish! let me break in a couple thousand miles first! I don't think it should be a problem though. The double tubes are holding the ankle just fine.
I will admit it's a different beast then rocking my Pumas. I was so able to get underneath the shifter quickly (with the Pumas). It took me a little time to adjust to that with the SIDI's
Old Aug 30, 2007 | 11:55 AM
EHonda's Avatar
I think you should go for the snug fitting boot. Boots tend to break in after awhile, so the 44's should be pretty comfy in no time.
Old Aug 30, 2007 | 03:15 PM
CBRYDR's Avatar
The 44's were tight beyond explanation! I mean my feet will be in PAIN after a short ride! The 45's are a little discomforting as it stands. Either than that, it's good to go!
estate4life
Riding Gear
Apr 27, 2012 01:48 PM
PHXf4i
Riding Gear
Jul 14, 2007 10:28 PM
