Riding Gear Questions and reviews about jackets, helmets, gloves, etc.
Shoei size
Old Jan 10, 2006 | 09:56 PM
greyd's Avatar
Default Shoei size
Might be buying a Shoei rf-1000 but there are no stores close to try one on for size. My melon measures 22"1/4 by their measuring system, so do you think a small would fit best?? What size are your heads that fit small or mediums?
Thanks
Old Jan 11, 2006 | 03:19 AM
HighRevver's Avatar
Default RE: Shoei size
First of all great choice you won't be dissapointed. With personal experience (i own a shoei rf1000) they run big, my MX helmet (Fox) is a large...I put on a large shoei, LoL i could barely get it off my head, then the XL was a big jump up and it fit like a glove!
Old Jan 11, 2006 | 06:07 AM
Chaos's Avatar
my helmets are shoei xr 1000 and my melons 58.5 cm or 23" i have a large and while perfect on fit
it has given a bit with wearing and is very slighty loose, my wife's is 55cm and she has the small helmet & good fit,
from your size you gave it sounds like you are slightly between the sizing like i was, so my advice would be go for the small as it may be slightly tight at first but it will definately give a bit, also another option is that
each helmet comes with standard cheek pads but there are two other sizes of pad available for each helmet size giving more flexability
eg/ size small, standard cheekpad is 39, the other options are 37 or 41 etc..
hope this helps [8D]
Shoei Helmets Sizing Chart
Sizes Inch Hat Size cm
XX-Small 21-1/8" 6-3/8 - 6-1/2 51-52
X-Small 21-1/4" 6-5/8 - 6-3/4 53-54
Small 21-5/8" 6-7/8 - 7 55-56
Medium 22-3/8" 7-1/8 - 7-1/4 57-58
Large 23-1/8" 7-3/8 - 7-1/2 59-60
X-Large 23-1/2" 7-5/8 - 7-3/4 61-62
XX-Large 24-1/4" 7-7/8 - 8 63-64
XXX-Large 24-5/8" 8-3/8 - 8-1/2 65-66
