my ride
Old Aug 18, 2009 | 07:53 PM
kilgoretrout's Avatar
Administrator - Retired
Thanks for the answers, Jim. Very cool little car you've got there...
As far as fuel mix, you're definately gonna be running lean with the k&n filters like that..
Upsizing your jets is probably in order here.
Are you running a fuel pump in this? I guess with 2psi, you must be...
Depenidng on where you mount the fuel tank, I guess you'd have to.
Anyway, I think todd is on the money with upgrading jets. Others have had to do the same when removing the stock box.
Old Aug 19, 2009 | 12:39 PM
jimfai's Avatar
Talking ride
again, thanks to all of you on here for the help, yes fuel pump. i have another older mini that i put a puegeot engine transplant in and i use R1 bike carbs, i know these need 1.5 to 2 lbs psi to run correct so that is what i used as start point. where would you recommend to buy the bigger jets from?
Bad600RR
Jul 24, 2016 02:41 AM
thirdgenlxi
May 18, 2009 01:24 AM
njdjh2o
Mar 18, 2009 03:56 PM
CBR13F2
Mar 25, 2008 11:42 AM
VITIATED
Jun 28, 2005 12:16 AM
