Scorpion Helmets
#32
#35
#36
I've been able to put my head in just about any attitude, no problems. There is a little adjustment on the shield mechanism on the side. They give you 2 extra nylon screws when you purchase because they may wear and give a little play. Adjust your shield to flat surface by running your finger over the seam.
Q: Do you have a lot of breeze from the chin area? I used to wear a chin guard and it helps a little. If you have a lot of chin breeze, perhaps it was a positive pressure issue...maybe I should dig up my Scorpion rep's number and ask about this...
#37
The EXO-1000 has this lock, though I've also never heard of this problem. Did you have the visor cracked open? I don't know about the 700, but the 1000 has little notches in the hinges to hold the visor in place, and also springs. Perhaps yours are worn?
#38
I've got an EXO-1000 and its just plain awesome. It's light as hell, and incredibly comfortable over long periods of time, even with the pads inflated. Stays COOL if you leave the vents open, even in this humid 80-degree Chicago weather. Seriously, I've never gotten this helmet all sweaty, even after a whole day of riding.
It's got a neat "defogger" system that takes in air from the "mouth" vent, and blows it stright up across the inside of the visor (you can see the little vents in the picture). Works really well. It also lets you crack open the visor about 1cm for faster defogging or a nice cool breeze on the face while still maintaining eye safety. There's also a visor lock to prevent it from flying open at high speeds.
Best part (for me): I took a hit with it. Clutch slipped on a turn, and the rear wheel spun out. I low-sided, but was going under 5mph, so I didn't really slide. Just landed on my hip and shoulder, which caused my head to bounce off the asphalt. I sent the helmet off to Scorpion, and they said the shock absorbtion is totally fine, and they recertified it as safe to use. It actually took a legitimate hit, and was still fine (Don't try this at home, kids)!
I love this helmet, and while I'm no connoisseur, I do get a lot of the "bike guys" at gatherings and stuff who want to look at it and think everything about it is really cool. If you get one of the plain ones (no graphics), you can ****** it up for about $300, which is a nice price for such an amazing helmet.
PS: The Kanji decals are not stock, I put those there.
#39
#40
. . .I have no idea what you're talking about. Are you referring to the built-in tinted lenses? Those lift up into the housing. When they're fully up, they're not in your field of vision at all, as they raise higher than the top of the visor. Either you didn't have them raised fully, or you had some busted-up display model you were trying out.
